Séminaire C2 le vendredi 25 janvier 2019 dans la salle 105 du LIP6
La prochaine édition du séminaire C2 se tiendra le vendredi 25 janvier  2019 dans la salle 105 couloir 25-26 du LIP6 de Sorbonne Université, métro Jussieu.
  • 10h00 – Virginie Lallemand, LORIA : Multiplication Operated Encryption with Trojan Resilience
Résumé : In order to lower costs, the fabrication of Integrated Circuits is increasingly delegated to offshore contract foundries, making themexposed to malicious modifications, known as hardware Trojans. Recent works have demonstrated that a strong form of Trojan-resilience can be obtained from untrusted chips by exploiting secret sharing and Multi-Party Computation (MPC), yet with significant cost overheads. In this talk, we examine the possibility of building a symmetric cipher enabling similar guarantees in a more efficient manner. The solution proposed exploits a simple round structure mixing a modular multiplication and a multiplication with a binary matrix. Besides being motivated as a new block cipher design for Trojan resilience, our research also exposes the cryptographic properties of the modular multiplication, which is of independent interest.
Based on joint work with Olivier Bronchain, Sebastian Faust, Gregor Leander, Léo Perrin and François-Xavier Standaert
  • 11h15 : Antoine Grospellier, INRIA : Constant overhead quantum fault-tolerance with quantum expander codes
Résumé :We prove that quantum expander codes can be combined with quantum fault-tolerance techniques to achieve constant overhead: the ratio between the total number of physical qubits required for a quantum computation with faulty hardware and the number of logical qubits involved in the ideal computation is asymptotically constant, and can even be taken arbitrarily close to 1 in the limit of small physical error rate. This improves on the polylogarithmic overhead promised by the standard threshold theorem. To achieve this, we exploit a framework introduced by Gottesman together with a family of constant rate quantum codes, quantum expander codes. Our main technical contribution is to analyze an efficient decoding algorithm for these codes and prove that it remains robust in the presence of noisy syndrome measurements, a property which is crucial for fault-tolerant circuits. We also establish two additional features of the decoding algorithm that make it attractive for quantum computation: it can be parallelized to run in logarithmic depth, and is single-shot, meaning that it only requires a single round of noisy syndrome measurement.
  • 13h45 : Elise Barelli, Université de Versailles – Saint-Quentin, Équipe CRYPTO, Laboratoire LMV : Étude de clés compactes pour le schéma de McEliece utilisant des codes géométriques avec des automorphismes non triviaux.
Résumé : En 1978, McEliece introduit un système de chiffrement basé sur l’utilisation des codes linéaires et propose d’utiliser les codes de Goppa classiques, ie: des sous-codes sur un sous-corps de codes algébriques (AG codes) construit sur une courbe de genre 0. Cette proposition reste sécurisé et dans le but d’introduire une généralisation de ces codes, en 1996, H. Janwa et O. Moreno proposent d’utiliser des sous-codes sur un sous corps de codes construits à partir de courbes de genre > 0 , on les appelle les SSAG codes (Subfield Subcode of AG codes). Cette proposition donne un plus grand choix de code puisqu’on peut faire varier la courbe, le genre, et les points rationnels du diviseur qui génère le code. Le principal obstacle à l’utilisation de ces codes en cryptographie reste le taille de la clé publique comparé aux autres systèmes à clé publique. Pour contourner cette limitation, on réduit la taille des clés en utilisant des codes qui admettent une matrice génératrice compacte. Un moyen d’obtenir des matrices compactes est de choisir des codes avec un groupe d’automorphismes non-trivial, par exemple on utilise des SSAG codes quasi-cycliques.
  • 15h00 : Julien Lavauzelle, IRMAR, Université de Rennes 1 : Constructions de protocoles de PIR
Résumé : Un protocole de récupération confidentielle d’information (private information retrieval, PIR) permet d’extraire l’entrée D_i d’une base de données D, sans révéler d’information sur i à l’entité qui détient D.
Dans cet exposé, nous donnerons un aperçu de techniques existantes pour la construction de tels protocoles. Nous préciserons notamment des paramètres qui quantifient leur efficacité, tels que la complexité algorithmique des serveurs, la complexité de communication ou la redondance de stockage.
Nous présenterons enfin deux constructions de protocoles de PIR. La première, fondée sur des objets combinatoires appelés designs transversaux, atteint une complexité calculatoire optimale pour les serveurs qui détiennent la base de données. La seconde se concentre sur la complexité de communication, et se place dans le contexte de fichiers encodés à l’aide de codes régénérants optimaux.
